03-26-2020 14:54
03-26-2020 14:54
When I first got and set up my Fitbit Versa light special edition watch, texts & calls showed up on my Fitbit but now nothing. I don’t get texts, phone calls or notifications on my Fitbit.
very frustrating.
sandy
03-26-2020 18:37
03-26-2020 18:37
Hi @Sands10 What phone are you using? (Make and model)
First check that DO NOT DISTURB is not accidently turned on - swipe down - it is the white circle with the line through it.
Try all the suggestions in THIS Help Article on Troubleshooting Notifications.
Helen | Western Australia
03-26-2020 19:02
03-26-2020 19:02
03-26-2020 23:46
03-26-2020 23:46
Thanks for checking that. As it is an iOS phone the problem is possibly what is talked about HERE . Go through the steps KateFitbit outlines and hopefully that will fix your problems.
(If you go to the Settings app on your watch, you need to scroll right to the bottom to find About)
