07-30-2022
15:10
17:44
07-30-2022
15:10
17:44
Mi fitbit es como si se hubiese muerto, no funciona, no se enciende
07-30-2022 23:45
07-30-2022 23:45
Hola @Alcaerba - it may not actually be charged.
If you look at the charge in the Fitbit App also check when it last synced to see when that was.
The most common cause is a bad charge cable or it needs cleaning, see How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
If it gets hot while charging stop immediately, there may be an internal fault.
