05-03-2020 20:12 - last edited on 05-04-2020 17:32 by LiliyaFitbit
Nothing with voice works.at all on watch. Any fixes or just broke?
05-10-2021 18:49
05-10-2021 18:49
Same as Goodwrench13.jl, Alexa will not "hear me" unless I tap hard on the mic repeatedly and I see the lines start to move. and sometimes not even then. very frustrating.
Please help.
05-04-2020 17:32
05-04-2020 17:32
Welcome to the Fitbit Community, @Dcoles58.
I am sorry to hear that the microphone on your Versa 2 watch is not working. Thanks for trying to resolve this and I am here to help. I understand your concern and recommend following the troubleshooting instructions in this help article: What should I do if Alexa doesn’t work on my Fitbit watch?
Let me know how it goes, I'll be around.
05-12-2020 06:32
05-12-2020 06:32
I am having the same issue. I press the button for Alexa it comes up, but when I speak nothing happens. The watch is clearly not hearing anything being spoken.
05-12-2020 07:12
05-12-2020 07:12
Hi everyone - I have one more suggestion. From the clock face on your Versa, swipe to the left to find Settings. Tap that. Then swipe to Microphone. Make sure it is Enabled. Then swipe to the right, all the way back to the clock face. This will save your setting.
05-12-2020 07:24
05-12-2020 07:24
05-13-2020 14:28
05-13-2020 14:28
Welcome to the Fitbit Community, @NateB225. It's nice to see you around, @SunsetRunner.
@SunsetRunner thank you for your helpful tips and support!
@NateB225 thank you for joining the thread and sharing that you're experiencing the same issue. I appreciate your efforts to resolve it, I am glad to assist you. If you've checked already this article with helpful instructions, I recommend restarting your device: How do I restart my Fitbit device?
Keep me posted on the outcome.
05-14-2020 07:13
05-14-2020 07:13
05-14-2020 11:27
05-14-2020 11:27
Hi @NateB225, thank you for your reply.
I appreciate your efforts and the additional details. Since the issue persists, I've sent your information to the Customer Support team so they can get in touch with you and provide further assistance. You should be getting a reply soon.
Let me know if you have any questions.
07-30-2020 13:31
07-30-2020 13:31
Hi i am having the same issue as the said... And i also have shut it down and turned ot back on... Mic is enable as well... What do i do?
08-16-2020 06:35
08-16-2020 06:35
I have the same issue. Alexa is "listening" but there is no response to my voice. The microphone is enabled. Has been since I originally set up device. I have synched and refreshed several times. I have restarted the Versa 2. Still same. I am unable to respond to text messages either. Must be a problem with the microphone. Please help.
08-22-2020
14:36
07:20
JuanJoFitbit
08-22-2020
14:36
07:20
JuanJoFitbit
I am also having issues since the last update.
When I try to use the mic it picks up my voice but returns the following message:
"How can I help?"
Any help much appreciated.
I have done a factory restart and uninstalled and reinstalled the app.
Moderator edit: merged reply
10-29-2020 09:00
10-29-2020 09:00
I have had the same problem with my Alexa not working on my Versa 2. It's very frustrating since that was the reason I bought the Versa 2, to have Alexa on my wrist. I finally realized it was probably the microphone and it was because of the last update. I did a factory reset but it added the same update to my watch so the mic still doesn't work. Kind of not happy with Fitbit right now as they seem to not be trying to fix this problem.
10-29-2020 15:24
10-29-2020 15:24
Mine has started to work again.
I didn't do anything since my post so do not know how it fixed itself.
11-20-2020 10:11
11-20-2020 10:11
I'm having the same issue I have tried every thing to fix it with no luck at all. It's not just Alexa also when I try to respond to a text with the microphone it also doesn't work or understand what I'm saying. I've read all the posts and tried all the fixes. Still nothing.
11-29-2020 18:54
11-29-2020 18:54
I got my versa 2 nine days ago and the microphone stopped working after messing with it for a while I realized if I tap on it with a knuckle right above the microphone it will work
01-22-2021 09:00
01-22-2021 09:00
I have been having the same issue. Was Fitbit able to fix this problem for you? If so, how was it fixed?
03-28-2021 20:09
03-28-2021 20:09
I was able to enable the microphone. But I don't get to swipe to the right if I swipe to the right it disabled by microphone. The only way to get back to the home screen is click the button on the side.
05-10-2021 18:49
05-10-2021 18:49
Please help.
06-07-2021 13:39
06-07-2021 13:39
I am having the same issue and have tried all the recommended fixes. I have to tap hard on the microphone for Alexa to "hear" me and when I try to reply to a text it will not register my voice. Seems this is a known issue. How can customer support help?
07-25-2021 20:13 - edited 07-25-2021 20:14
I do not believe they can help. They are refusing to acknowledge that it is an issue and will give you the runaround. I guess since Google purchased Fitbit, this is the service to expect, unfortunately. I have been given the runaround for almost a week. Chat and voice support are awful.
