05-03-2020 20:12 - last edited on 05-04-2020 17:32 by LiliyaFitbit
Nothing with voice works.at all on watch. Any fixes or just broke?
07-28-2021 11:07
07-28-2021 11:07
07-29-2021 11:43
07-29-2021 11:43
Thanks IRHera! Did you just open a support ticket of some kind?
07-29-2021 12:23
07-29-2021 12:23
07-31-2021 20:31
07-31-2021 20:31
Same here... opened a support ticket and they asked if I had rebooted the device. then they asked if I had factory reset the device. I said yes to both then they told me they would email me warenty info. Apparently I'm past my 1 year limited warranty so all they will offer me is a discount. I should have opened a ticket when I first had the issue. 😞
08-06-2021 20:09
08-06-2021 20:09
I have the same problem. The mic was working in the beginning thant it stoped.
08-10-2021 06:07
08-10-2021 06:07
I've been having the same issue with mine. After 2 months of getting the run around they offered me 30% off my next fitbit. My versa still works fine its only the microphone messing up so I figured I'd just keep it and live with it. I can't believe so many people are having this issue and it's not being addressed.
09-13-2021 08:59
09-13-2021 08:59
Any updates on a microphone fix? I've been dealing with it since the last update. Would be great to have it working again. The microphone is enabled - just doesn't hear me.
09-13-2021 09:20
09-13-2021 09:20
09-13-2021 10:09
09-13-2021 10:09
01-10-2022 15:14
01-10-2022 15:14
How do i even set up a microphone on my versa 2
02-16-2022 19:25
02-16-2022 19:25
I have tried everything that has been suggested and still don't work.
03-03-2022 07:58
03-03-2022 07:58
I had the same problem, the only thing that the microphone would register was taps on the face. The solution for me was to clean the port to the microphone (small hole on the opposite side of the face from the button). Mine was dirty/clogged and this apparently was preventing the microphone from being able to pick up my voice.
03-13-2022 04:43
03-13-2022 04:43
How did you clean it?
06-22-2022 13:04
06-22-2022 13:04
I'm on Versa 2 #3, all under warranty, same issue. Will NEVER buy another FitBit product, the only thing it is 'fit' for is a paper weight, and who uses paper any more?
08-24-2022 19:43
08-24-2022 19:43
Same here, since the update the microphone isn't working
06-02-2023 08:04
06-02-2023 08:04
For anyone who references this later, it's a common issue. Fitbit customer service is atrocious and you likely will not get a replacement or fix. I've been trying to get them to fix it for 2 months and they won't budge. They won't honor the warranty. Unfortunately it's outside of my window for a chargeback.
