10-03-2019 12:03
10-03-2019 12:03
I went swimming for the 2nd or 3rd time since getting my fitbit versa in June 2018, it's always worked fine afterwards and seemed to be the same this time. Now a few hours after it won't turn on, doesn't seem to charge, it had over 50% battery. I can see moisture in the sensors, which I'm guessing is the problem. Any ideas?
10-03-2019 13:14
10-03-2019 13:14
Welcome to the forums!
I would put it in Rice for 48 hours to dry out the moisture. Hopefully it will come back
Let us know!
Wendy | CA | Moto G6 Android
