09-17-2019 08:23
09-17-2019 08:23
Hello, I have a question about BlueTooth devices to listen to Music on my Versa SmartWatch. What is the best or recommended headphones, buds, or etc to listen to Music with on the Versa?
Thank you,
09-17-2019 10:36
09-17-2019 10:36
Anything bluetooth should work. There is some specification for bluetooth version but I think anything bought new meets that.
I got $20 bluetooth earbuds from Amazon that sound great to my older ears.
Or you can spend over $500 on them. It depends on your finances, taste, audio sensitivity, what is comfortable to you, etc.
What is great for a workout might not be what one might choose for serious dedicated listening to classical music.
Best Answer09-17-2019 10:45
09-17-2019 10:45
Best Answer09-17-2019 10:46
09-17-2019 10:46
Hello,
Thank you for the quick reply. $20 sounds great. What Brand/Model on Amazon and I will purchase them immediately. Especially since you confirmed they work with FitBit Versa.
Thank You,
Best Answer09-17-2019 11:08
09-17-2019 11:08
Thew ones I bought are no longer listed on Amazon. As I recall, there were several models/brands that all looked the same. I suspect they were all the same by a Chinese company giving marketing rights to different companies.
Check your messages - I don't want to look like I am pushing any brand here.
Best Answer09-17-2019 11:14
09-17-2019 11:14
Best Answer09-30-2019 03:50
09-30-2019 03:50
Hi
It gets hit and miss for what works even though the manufacturer says they should.
I recently got a pair of £49 JLab Air buds and they work perfectly with my Versa 1 (the sound is excellent too)
Best Answer09-30-2019 06:51
09-30-2019 06:51
Hello,
Thank you for the note. I have a few pairs, and none of them really work very well. It seems they are "hit and miss"... The JLab Air Buds sound like the right ones...but they cost more though... ; - (
Thanks,
Best Answer09-30-2019 07:07
09-30-2019 07:07
You're welcome....and correct in that they cost more.....but they do work.
I have a pair of Bose that work perfectly as well but I wouldn't want to risk them out on the street.(too expensive)
I tried a JLab pair that cost me £20/$20 and they didn't work with the Versa 1 (bad stuttering sound no matter what I did)
You could go down the route of trying various from Amazon and seeing if they work and return if not.
Best Answer09-30-2019 11:18
09-30-2019 11:18
Thank you Sir.
Best Answer10-02-2019 11:20
10-02-2019 11:20
Best Answer10-02-2019 11:21
10-02-2019 11:21
Hello,
Are the JLab Air Buds the best? What is the part number or code so I order the right ones from Amazon?
Thanks,
Best Answer10-02-2019 12:48
10-02-2019 12:48
