04-20-2018
11:58
07:15
HeydyF
04-20-2018
11:58
07:15
HeydyF
Hi all I don't know if anyone else is having this problem...yet another problem with my versa
If I go out I put my music on after about ten steps it beeps loudly twice. Then for the next 7 to 10 mins the music is jumpy and distorted, then it plays perfect when it is nearly time to finish my walk, very annoying.
Moderator edit: format and updated subject for clarity
03-07-2019 06:27
03-07-2019 06:27
Hello,
I tried resetting my Fitbit, turning it off and even unpairing/pairing my headphones again and nothing worked I don't know what to do to turn down my volume since it does not want to turn down, could you please help someone that already did what you told us. (I also reset my watch 4 times).
03-12-2019 12:04
03-12-2019 12:04
I tried the suggested fix and no change. I'm not trying to connect to headphones though, I'm trying to connect to a speaker, I'm also using my own playlist rather than Pandora/Deezer. The speaker is not connected to my phone and I've already disconnected it from the Versa and reconnected - still no change
Best Answer05-11-2019 21:37
05-11-2019 21:37
Any further suggestions? My husband gifted me a new Versa for Mother's Day, I chose the Versa for it's ability to play music and all I get from it is highly distorted music that's unbearable. I've already tried the "solution" multiple times.
12-27-2019 12:32
12-27-2019 12:32
Hi. I tried rebooting Versa 2 twice and un-pairing the phones twice, without and improvement in the sound quality. What can we do now?
Best Answer01-12-2020 08:56
01-12-2020 08:56
Please just be honest and straight and admit this is an issue with the Fitbit
I have now tried mine on 8 separate Bluetooth headsets, ranging in price £170, £110, £70, £50, £50, £40, £25 and £10 and it happens in each case
I've factory reset, rebooted, unpaired, re-paired etc but the problem persists
Don't blame other apps (I have none) or space (it's the same if I only have 2 tracks) or the tracks (sometimes they play fine) or how I wear the Fitbit (on my arm) or how I move (it happens even if I'm sitting on the couch)
Put the blame where it lies - Fitbit Bluetooth is not fit for purpose
01-13-2020 01:36
01-13-2020 01:36
Best Answer01-15-2020 14:20
01-15-2020 14:20
Hi. Have you tried to switch off Bluetooth on your phone temporarily and then try to pairing your smart speaker. It worked for me!
Best Answer01-29-2020 11:28
01-29-2020 11:28
Thank you.
My new Versa was registering my sleep but all of a sudden stopped doing it. I tightened it, moved it higher but nothing.
So I just restarted it as you suggested and now I will go to my app and check my sleeping mode.
I will keep you updated!
Thank you for your ideas!
Carolyn
Best Answer01-31-2020 09:34
01-31-2020 09:34
Ran through all these steps and now my versa won't connect to my Galaxy earbuds. What am I doing wrong?
Best Answer01-31-2020 09:37
01-31-2020 09:37
Best Answer02-08-2020 07:11
02-08-2020 07:11
This did not work for me. Done several times and music still bad
Best Answer03-02-2020 00:59
03-02-2020 00:59
I’ve only bought my versa2 yesterday and instantly regretted it when my usual earphones distorted the music I was trying to play, then searched the net and realised its a common issue.
I was about to embark on the search for ones that would work, when I remembered I had some older ones in a drawer. They work great, so if this can help anyone, here goes:
Best Answer07-11-2020 14:33
07-11-2020 14:33
Did not even work. WHY!?!?!?
Best Answer04-15-2021 13:09
04-15-2021 13:09
Mine is doing the same thing! I’ve rebooted, re-installed and everything else it said to do and my music is still sped up and spotty! It is pi$$ing me off too! I paid too much money for this crap to happen!
04-16-2021 03:11
04-16-2021 03:11
They keep pushing me to buy the sense. Why would I buy the sense when I spent a fortune on the versa and it didn't even do the job I bought it for, that it lists as one of it's main features
04-18-2021 04:04
04-18-2021 04:04
I'm having the same problem. It was the main reason I bought the Versa instead of sticking with the Inspire. I've rebooted everything. My Bluetooth headset works fine with my phone, my Kindle, and my Bluetooth speaker. I came here to see if there was an answer and am dismayed to see this is a problem going back years!
