01-23-2019 18:09
01-23-2019 18:09
Hi, I really like the FitBit Versa but, I am having some issues. Normally when I sync my versa it does not sync when I want it to. I have tried syncing it from a kindle fire, iPad, and ZTE phone, but it still will not work. My FitBit does require a manual update that I want to update my Versa and get to apps and clock faces on my Versa. I have tried syncing it many times but it has not worked. It will sync about once or twice a day, but I want it to connect to my device so I can install/unistall apps. Thanks in advance!
Best Answer01-23-2019 21:09 - edited 01-23-2019 21:10
@SeleneD try restoring bluetooth connectivity before applying the update:
Additional tips if sync issues persist: If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues.
01-24-2019 07:17
01-24-2019 07:17
Ok thank you I will try that!
Best Answer03-20-2019 03:37
03-20-2019 03:37
I assume that when the Fitbit mobile app is removed, all my data is deleted? Is there a way to store the data on the iPad? Also is there a way to view my data over a range of time?
Best Answer03-21-2019 12:05
03-21-2019 12:05
@welshman No. Nothing is stored locally. Your data is stored on Fitbit servers so it gets downloaded each time you reinstall the app.
03-21-2019 12:23
03-21-2019 12:23
Best Answer03-21-2019 12:25
03-21-2019 12:25
@welshman you're welcome! you can have your data on multiple devices as it is stored in the cloud. 😄
