10-10-2019 11:45
10-10-2019 11:45
I haven't called yet but I got my Versa 2 Oct. 8th and it's bricked. I reset it, I turned off and restarted my Bluetooth, and tried everything else but nothing works. I already have a Versa and made sure it was disconnected and tried again...nothing. It still looks the same as it did when I unboxed it. It came to life twice, and when I put in the number on the screen nothing happened. I did this twice and it went back to the original screen instead of continuing. I messed with it for 2 days now and I want to see what somebody has to say here before I return it for the brick that it is.
My phone is a Galaxy S10+ but has no problems with my old Versa.
One time it showed up on the Fitbit app but while doing this wouldn't sync or show up in Bluetooth. Therefore, I couldn't update it or do anything with it especially when I looked at the bracelet itself only to see it was on the same brick screen I opened the box to. Without that working, nothing is going to work!!!
I am attaching a photo of the screen it came out of the box showing and the screen that now won't work for anything. It's at about 65% but won't charge anymore even though I left it plugged in for a day!
Hope to hear something soon I searched the community and didn't see much about it.
10-10-2019 12:14
10-10-2019 12:14
Your phone is not on the list of Approved Devices.
10-10-2019 14:05
10-10-2019 14:05
Have you tried this?
FitBit app Settings - select Versa scroll down & select Remove this Versa.
Then go Bluetooth settings & manually 'unpair' Versa.
Completely uninstall the FitBit app.
Shut down 'not restart' your phone.
Put Versa on charge.
Turn phone on.
Reinstall FitBit app.
Go settings + Set up a device
Follow on screen prompts.
Contact support if you need further guidance or help https://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
https://help.fitbit.com/articles/en_US/Help_article/2315
Samsung Galaxy S10+ is showing in this compatibility list.
Samsung | ||
Galaxy S10 | Galaxy S8 | Galaxy Note 5 |
Galaxy S10+ | Galaxy A8 | Galaxy J3 |
Galaxy S10e | Galaxy S7 Edge | Galaxy A6 |
Galaxy S9+ | Galaxy S7 | Galaxy Note 9 |
Galaxy S9 | Galaxy S6 Edge | |
Galaxy S8+ | Galaxy S6 |
10-12-2019 07:56
10-12-2019 07:56
Thank you I'll try that. I already did most of it but it's worth a try using your instructions. Thank you!
10-12-2019 07:57
10-12-2019 07:57
That's not true. My Galaxy S10+ is on the list.
