04-23-2018 17:33
04-23-2018 17:33
I can't receive texts (SMS app textra and messages tried)
Gmail comes through in duplicates.
Hangouts comes through for the first few chat messages then other messages are not relayed to the watch until a minute or so then it picks up again. RE syncing in the app fixes it for another message or two.
All Day Sync: ON
Always Connect: ON
Keep-Alive Widget: ON
(And tried every combination each and every way)
Hangouts check under notifications.
Reset watch and redid Bluetooth connection and app.
Oh and.... I can't control music. Volume works with watch buttons.
(Got music control to show but it was the wrong info on the screen and when you leave the bluetooth control screen and come back controls are gone again)
Bad first fitbit experience. Great health tracking and wow it knew exactly how many flights but **ahem**ed if it does any smart watch stuff.
04-25-2018 11:51
04-25-2018 11:51
It was an app called Reply (by google)
It reads messages and gives you responses in the context of the situation. (ie, in car it tells the person you are driving)
I deleted this app and texts work now on my pixel for my versa.
04-23-2018 20:49
04-23-2018 20:49
Try doing a factory reset and start over.
04-23-2018 21:49
04-23-2018 21:49
@SunsetRunner It sounds like it coukd be a compatability issue. Is your phone model on the Supported Devices List?
Helen | Western Australia
04-23-2018 22:03
04-23-2018 22:03
I'm also having issues with my pixel/versa combination. The Fitbit app doesn't show the apps on my versa or load the available apps. The notifications for text messages are not coming through either. The wallet won't appear when holding the back button down either.
04-24-2018 07:04
04-24-2018 07:04
Yes. It's a supported phone.
I factory reset the watch but no way should I have to reset the phone. Fitbit needs to build a working product like Androidwear and Pebble before them.
Is there any log I can send to Fitbit? I haven't heard from a single Pixel owner where this or the ionic actually work after fit os 2.0
04-25-2018 08:18
04-25-2018 08:18
My versa is now working with whatever updates were made yesterday. No more issues with notifications or the wallet not appearing
04-25-2018 08:31
04-25-2018 08:31
I wonder if there is Bluetooth reconnect problems? I unpaired by Pebble Time when I started using my Versa.
Something may be competing with your phones bluetooth or bluetooth may not stay connected when idle?
04-25-2018 11:51
04-25-2018 11:51
04-25-2018 12:55
04-25-2018 12:55
@SunsetRunner oh wow, that doesn't seem intuitive, but I'm glad you found out what it was. Go Pixel! 🙂
