My Versa 2 battery discharges in less than 24 hours
My versa 2 battery discharges within 24 hours. The problem started when I noticed that it was discharging quickly I would plug it into charge and it would quickly ramp up to 100% then die after short usage. I changed the clock face I did a hard reset and I've turned off the location service. Now the battery lasts less than 24 hours. My question:is there a fix to this issue or does it require a new watch? Can the battery be replaced? If so how do I accomplish this?
Moderator Edit: Clarified subject.
1 REPLY 1
Hi there @Shockit2me!
A warm welcome to the Fitbit Community!
Thank you so much for sharing with us that your Versa 2 discharges within 24 hours and for all your efforts.
I suggest you follow the tips from this article: Can I extend my Fitbit device's battery life?
If the situation continues please try to contact support.
