My Versa 2 has a strange battery issue
My Versa 2 has a strange battery issue. If the battery shows anything from 100% to 88% the watch works fine and I can use it no problem for a day, maybe two with what seems to be minimal battery drain.
But If the battery is below 88% it lasts maybe 6 hours before being totally drained. What's worse is the speed it drains at increases as it depletes. The watch will be at 60% an hour later 50%, 1/2 hour later 40%, and once it reaches that point it takes less than an hour to completely drain.
Is that normal? This has happened 4 times now and it's reached the point where I have to charge it every morning to be certain it'll last the day just like I had to with my original Versa.
Where's this great battery life you guys keep talking about?
2 REPLIES 2
@Gezzer This is not normal, obviously. Do you have any 3rd party clockfaces or apps installed? Have you tried uninstalling them and rebooting the tracker several times? Have you tried a factory reset?
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
@Gezzer Did you manage to make it work properly?
