01-19-2021 06:52 - edited 01-19-2021 08:22
Hello,
I want temporally to use my PC to connect my versa 2, but the PC doesn't find it.
Here are more details:
* The system of the PC is Windows 10 up to date
* Bluetooth driver is up to date
* The versa is not connected to another device, I did a reset.
Thanks in advance.
01-19-2021
10:05
07:45
01-19-2021
10:05
07:45
Best Answer01-19-2021 10:26
01-19-2021 10:26
Yes. Thank you. Restart and reset. Apparently, the Fitbit support said just to use another device, and on a laptop the updates of the tracker are not done.
Basically, I can't use the device at all until I'll fix my phone.
Best Answer02-28-2021 06:23
02-28-2021 06:23
Again it happens to have the same issue. I may need to sell the Fitbit for a watch that I can sync with my laptop or PC.
Best Answer02-28-2021 06:35
02-28-2021 06:35
If your watch is connected to the computer, or was, you need to make sure that the Computer Bluetooth or the Computer are off when trying to use your phone to avoid any conflicts, as once you do a factory reset you need a phone to get it setup.
If you can get your phone to work, turn off the PC,
restart the watch and phone
In the phone Fitbit App Click on profile photo [top left] Click on + Set up a Device and Add your Versa 2 again Follow the installation instructions |
Best Answer02-28-2021 06:42
02-28-2021 06:42
I have the following:
1. Bluetooth on PC:
2 Versa 2 is reset and I have on the screen the green logo with all languages
3 Add a device on the PC: nothing
Best Answer02-28-2021 06:44
02-28-2021 06:44
In the APP on the PC:
and I have this - resetting the seeings as I showed before it doesn't work.
Best Answer02-28-2021 06:47
02-28-2021 06:47
I believe you can't add a factory reset watch on your computer, at least you can't load the firmware.
Best Answer02-28-2021 06:50
02-28-2021 06:50
In device number 2 a Lenovo laptop:
At least here is searching for the device:
I have the following and I'll remove the versa from the Bluetooth devices:
Now I need to restart and I'll post the next screenshots below.
02-28-2021 06:53 - edited 02-28-2021 06:53
So the versa has the green logo and the messages in all languages after a factory reset is done. This was already done before i started the process to connect to Fitbit app on the PC or laptop.
Best Answer02-28-2021 07:10
02-28-2021 07:10
after restart:
Now I have the Fitbit with a white logo and stuck, no clock face, no steps nothing. Below is the error.
Best Answer02-28-2021 07:18
02-28-2021 07:18
Now the Fitbit app gave this error. Yesterday I had the same error and I connected the Versa 2 to a phone and delete it from the Mobil phone. There is no customer support for this issue. I paid 200 USD for a SE Fitbit versa 2 not to be able to connect it to an app created by Fitbit for windows 10. This is BS.
