03-13-2021
06:07
18:44
EdsonFitbit
03-13-2021
06:07
18:44
EdsonFitbit
Off late the versa 2 is not getting reset when the date changes. Ie steps and entire data is getting added..
Further tracker is counting steps while drivng
03-14-2021 18:41 - edited 03-14-2021 18:43
Welcome to the Fitbit Community @Rujuta.
Thank you for the information provided.
Please make sure to have the latest version of the Fitbit app (3.39.1 iOS or 3.39.2 Android). For instructions on how to check your current version and update, please visit this article and open the menu "How do I update the Fitbit app?".
Your Fitbit Versa 2 has been tested against driving and riding in buses, trains, and other public transportation and shouldn’t add steps when you’re traveling under normal conditions. On bumpy roads or in a car with a stiff transmission your device may add some steps. For most customers, the number of extra steps added when driving isn’t significant when compared to your overall stats. If you want to remove the steps from your daily total, manually log the driving activity for the time you were in a vehicle. For more information, please visit this site and follow the instructions in the menu "How do I delete steps and floors in the Fitbit app?".
In addition, the dominant wrist setting decreases the sensitivity of step counting and should reduce any over counting of steps when your body is not moving. Your dominant hand is the one you use for writing and eating. You can find this setting if you go to the online Dashboard at fitbit.com > click the gear icon upper the right corner > Settings > click on your Versa 2 icon > Wrist.
If you continue experiencing difficulties, please restart your watch by following these steps.
Hope this helps.
