08-20-2021 02:40
08-20-2021 02:40
Hello,
I got my Versa 2 yesterday and before I had a Versa 1. On my previous one I was able to see my active zone minutes, but Versa 2 only shows active minutes. How can I change that?
Thanks
Ana
08-20-2021 03:48
08-20-2021 03:48
Hello @crazyanci and welcome to the Help forum. Your Versa 2 has the original firmware from when it was manufactured. Fitbit added active zone minutes in a firmware update. Fitbit is always sending out firmware updates and you got in line when you added your Versa 2 to your account. You should get an update in 24-48 hours.
I also want to advise you that you might not be able to set up certain apps on your Versa 2. They require the current firmware. Also, I don't know how many firmware updates have been made to the Versa 2. You might not get all of them at once. This happened to my husband when he put an Ionic on his account. But the current Versa 2 firmware is 72.1.15.
Laurie | Maryland
08-20-2021 10:46
08-20-2021 10:46
Thank you for your reply. I will wait for an update to show up and hopefully it will work then 🙂
