06-05-2022
16:04
18:00
06-05-2022
16:04
18:00
My Versa 3 all of a sudden has started showing the weather temperature in Celsius not Fahrenheit. I’ve check the phone app and it’s on Fahrenheit. I’ve tried switching to Celsius and syncing then switch back and sync, I’ve restarted the Fitbit and it’s still saying Celsius. Help on how to fix it
06-05-2022 17:43
06-05-2022 17:43
Same problem, same time--just today, suddenly-- evidently something system-wide. Can it be resolved at that level?
06-05-2022
18:18
08:58
06-05-2022
18:18
08:58
Welcome to the Fitbit Community, @Recessteacher @mfrisch.
Thank you for informing us about the issue you experienced with your Fitbit Versa 3 and for the troubleshooting steps you’ve performed.
If you followed these steps to change the units of measurement in your Fitbit accounts without luck, please set up your Watches as replacement devices:
Hope this helps.
Best Answer06-05-2022 20:52
06-05-2022 20:52
May be there was an update and the settings got lost.
See How to change Temperature - for Weather, Centigrade - Fahrenheit,to fix it.
06-05-2022 21:15
06-05-2022 21:15
Seriously the only reason I reposted it was I didn’t see my original post.
Best Answer06-05-2022 21:21
06-05-2022 21:21
@Recessteacher - it would seem your original post got deleted or somehow may have ended up in your profile, as you currently are showing having 3 posts but only 2 are visible.
06-05-2022 22:35
06-05-2022 22:35
I got mine fixed. I had to click on the app click on the profile picture, then on the picture of your device Versa 3. Then click on gallery scroll down until you see Weather then settings and make sure it’s in Fahrenheit
06-05-2022 22:38
06-05-2022 22:38
@Recessteacher - thanks for confirming the link I posted worked for you.
06-06-2022 05:13
06-06-2022 05:13
didnt work
Best Answer06-06-2022 05:30 - edited 06-06-2022 06:51
Hi @Whiterosez2000 did you follow all the steps in this link?
06-06-2022 06:00
06-06-2022 06:00
06-06-2022 06:34 - edited 06-06-2022 06:35
Well, followed the instructions--thx!!--for fixing temp via the App and now Fahrenheitnow shows on Versa 3. Likely a system update--also wiped the additional cities I had entered. Newbie question: When I open app on phone, it opens to the Today screen. Wasn't clear how to get to the profile. Finally, tapped the icon at top left, which was greyed out, which usualy means non-functioning. But it did take me back to the profile page and then instructions worked fine-- selected Fahrenheit and added back the cities I had entered. One other Q--someone posted a way to do this via the Versa 3, starting with Tap Today, then tap profile pic. But when I tap Today, it just opens the today categories-- don't see any profile pic or anything to tap...???
Best Answer06-06-2022 06:53
06-06-2022 06:53
@Whiterosez2000 , Jeannie, are you sure you didn't miss a step, like sync or use current location without cities?
06-06-2022 08:05
06-06-2022 08:05
I got my Versa 3 about a month ago. Upgraded from a Versa 2. Have had this problem from the get-go. Have tried every workaround to get the thing to reset to Fahrenheit with no success. It’s a FitBit fail. Instead of having customers jump thru hoops to get the app and the device working properly - they should solve the problem at their level. When paying this kind of $$ I expect it to work - and work as good as, if not better, than my old Versa 2.
08:10
08:57
06-06-2022
08:10
08:57
Hi @Babbl-on - it is odd indeed you have to change Temperature in 2 places.
Try following all the steps in this link?
06-06-2022 09:56
06-06-2022 09:56
That might have been me as I was typing in the direction from the link given.
06-06-2022 09:59
06-06-2022 09:59
Did you try the steps posted?
click on the icon at the top left
Click on the image of the Fitbit
click on gallery
scroll down to weather
click on settings and change to Fahrenheit
Best Answer06-06-2022 10:06
06-06-2022 10:06
10:09
08:57
06-07-2022
10:09
08:57
Thanks for getting back to us and I'm sorry to hear that you haven't been able to change your Weather Units @Whiterosez2000. Thank you for following advised troubleshooting steps.
I would recommend force quitting the Fitbit App, restarting your phone and trying the steps again. Have you entered multiple cities or only one?
Keep on visiting the forums.
06-15-2022 08:21
06-15-2022 08:21
Thank you! been struggling this issue for months. Didn't realize it was a clock clock face issue.
