05-01-2020
23:18
18:34
DavideFitbit
05-01-2020
23:18
18:34
DavideFitbit
My Versa Lite is losing time. The correct time at the moment is 07.16. My Fitbit is showing 06.26. This has been going on for a few days now..
Best Answer05-02-2020 01:51
05-02-2020 01:51
Hi @Helenc_25 Is your Versa Lite syncing OK? Try restarting it several times and sync again and see if that corrects it.
Helen | Western Australia
Best Answer05-06-2020 00:55
05-06-2020 00:55
Best Answer05-06-2020 01:05
05-06-2020 01:05
I am having the same problem go to sync and update and then will not find th device it is frustrating to a point I want to throw in bin use it as alarm in the morning and can lose up to 20 - 25 minutes overnight
Best Answer05-06-2020 01:49
05-06-2020 01:49
@Helenc_25 Then you will need to contact Customer Support
