11-22-2020 14:31
11-22-2020 14:31
Before someone tells me to go ahead and turn on the sleep analysis thing (that’s already been done before I even went to sleep). The settings are fine. I have since rebooted the Versa itself.
This is more a question about if anyone has ever experienced being a super deep sleeper or just being a weird sleeper and having the app not recognize your sleep? I have also switched the thing from normal to sensitive. I have a feeling I am a very deep sleeper, and that might be messing up the thing.
11-22-2020 15:17
11-22-2020 15:17
1. There is no "sleep analysis thing" to turn on. If you mean the "Begin Sleep Now" button, that is just for trackers without heart rate sensors.
2. Did it not log sleep at all, or do you mean just not the sleep stages analysis?
3. Is the the first night you have worn it?
11-22-2020 17:58 - edited 11-26-2020 07:10
Thanks! I meant the sleep analysis mode. Whatever that is called under
the ‘sleep’ settings.
analysis?
It did not do the sleep stage analysis, which I really wanted to see. I’m
a crazy deep sleeper (or so I think) and I was wondering about it.
Yes, first night.
____________________________________
11-22-2020 19:48 - edited 11-22-2020 19:50
Normal/sensitive setting is irrelevant with heart rate trackers. That was just for before heart rate, when fitbit just had to rely on movement to figure out if asleep.
I can't imagine being a deep sleeper would be a problem.
Some nights I just don't get sleep stages, just the asleep, awake, and restless, without knowing why.
Also it can take take a while for the sleep info to update.
From What should I know about Fitbit sleep stages?
"There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
For more information about why you see your sleep pattern, tap or click the sleep record that shows your sleep pattern."
11-23-2020 06:39 - edited 11-26-2020 07:11
I had it on sensitive and it said I slept 43 mins. I know I slept from
around 10:30 pm to about 6:15 am this morning. Oh well.--
