02-04-2019
01:19
11:16
HeydyF
02-04-2019
01:19
11:16
HeydyF
My versa stop tracking my pulse. For a couple of days now my pulse has bin stuck on the same nummer. I did a restart of my versa and now its just three dots were the puls should show, why
02-04-2019 15:58
02-04-2019 15:58
@VJO if you have tried all the steps listed above, including factory reset, and your Versa is still not cooperating, I'm afraid you might need to reach out to Customer Support to guide you through the next steps. I'm sorry I couldn't help more.
02-04-2019 01:59
02-04-2019 01:59
@VJO Open settings app on your Versa, scroll to heart rate and toggle OFF and back ON several times with a reboot of the tracker in-between (press and hold the left and bottom right buttons until Fitbit logo appears). Also, make sure you're wearing your Fitbit tight enough and that the battery is not too low as your Versa may turn off heart rate sensor and notifications then.
02-04-2019 03:37
02-04-2019 03:37
How many times do you have to do that. Done it a few times and nothing change.
Best Answer02-04-2019 11:15
02-04-2019 11:15
Hey @VJO, I hope you are doin' fine! I appreciate you have tried to restart your Versa and tried some of the tips that @Marrrmaduke suggested, so your Versa tracks your heart rate. Beside that, I'd like to suggest you something else. Could you please try to set up your Versa as a new device? Follow the instructions in this help article to do so.
Let us know how it goes!
02-04-2019 11:50
02-04-2019 11:50
Best Answer02-04-2019 15:58
02-04-2019 15:58
02-05-2019 02:00
02-05-2019 02:00
02-05-2019 09:16
02-05-2019 09:16
I will appreciate that you let us know the outcome after you contacted our Support team, @VJO.
Thanks for your help @Marrrmaduke!
Have a nice day guys!
02-05-2019 11:52
02-05-2019 11:52
thank you! that fixed it
02-06-2019
04:45
10:34
02-06-2019
04:45
10:34
Hey @DustyMoreno, welcome to the Community! Oh! Sounds great that your Versa is recording your heart rate accurately! 🙂
If you have further questions or comments, please keep me posted!
02-06-2019 05:36
02-06-2019 05:36
08:49
10:34
02-06-2019
08:49
10:34
Hey @VJO! You are getting messages from this thread because you created it and you are participating on it. Now in regards of your Versa, I'd like to know if you contacted our Support team for further help. If so, what did they tell you about this? Did they helped you out?
Let me know!
02-06-2019 13:30
02-06-2019 13:30
@DustyMoreno I'm glad it helped! And, thank you @HeydyF. As always you rock! 🤗
02-06-2019 23:41
02-06-2019 23:41
Best Answer02-07-2019 00:45
02-07-2019 00:45
My versa does nit track my pulse, only shows 3 dots...
it also does not log my sleep time.
Can I reset it to get it to work again!
Best Answer02-07-2019 00:50
02-07-2019 00:50
Thank you for the advice, it now does show my pulse again.
Best Answer02-07-2019 16:36
02-07-2019 16:36
@Walkthepaddies I'm glad we could help. 😊 @VJO Yay for the new Versa! 👍🏻
02-08-2019
08:45
10:33
02-08-2019
08:45
10:33
I appreciate the update guys @VJO and @Walkthepaddies. If you have further questions or comments, don't hesitate to let me know!
I'll be around!
