10-28-2019
19:21
03:14
JuanJoFitbit
10-28-2019
19:21
03:14
JuanJoFitbit
Though I'm using the charger that came with my versa classic I often get a message that its either charging slowly because I'm not using the original charger or just not using original charger. And it does charge slowly.
10-28-2019 20:38
10-28-2019 20:38
Hi @Tejano57 how are you charging the device? You using a power bank, tablet or laptop that is using power and not plugged into the electric?
10-29-2019
16:31
06:42
10-29-2019
16:31
06:42
Hi @Tejano57, welcome to the Community Forums!
Thanks for bringing this to my attention. If you haven't already done so, I recommend you to check our help article:How do I charge my Fitbit device? for instructions of how to properly charge your Fitbit device. Such article also includes a restart process which can be really helpful for this situation.
@Odyssey13 Your support is always appreciated! Thanks for the questions that were asked.
Let me know if you have any additional questions.
12-30-2020 07:53 - edited 12-30-2020 07:53
I get this message no matter how or where I charge. Plug into laptop: check. Plug into USB wall outlet: check. Plug into power bank: check. No matter where I plug it in, I always get this message. Also restarting does nothing to prevent the message. I always get it. FITBIT SENSE
12-30-2020 07:58
12-30-2020 07:58
Hi @susandennis is your laptop plugged in when you put the Fitbit charger in it? Not all power banks work to charge our Fitbits. I tried out several of my power banks and only a very few of them have enough juice to power the Fitbit. Are you able to charge, despite the message?
12-30-2020 08:13
12-30-2020 08:13
I get the error if my laptop is plugged in or not. Makes no difference. I have tried a variety of power banks, and wall plugs, and wall outlets. No matter what I use, I get the error. Have since the day I got my Sense. And, yes, I am able to charge despite the message.
02-17-2021 16:37
02-17-2021 16:37
Some USB chargers have much lower capacity than others. IOTW, the brick that your charger is plugged into. That can easily cause a slow charge. Plus over time some get weaker and weaker.
Having said that, I gather you are using the original magnetic dongle that came with your Sense. I'm running into my own problem - I bought a 'spare' dongle in the form of a stand and always get charging slowly message regardless of what USB brick I use. Having just gotten both the Sense and stand, I'm guessing my new Sense is OK, but my stand is either defective or poorly designed.
02-27-2021 17:31
02-27-2021 17:31
I just got a brand new Sense and I have tried multiple outlets and also my PC. It says slow charging no matter what I do.
02-27-2021 18:53
02-27-2021 18:53
02-27-2021 19:55
02-27-2021 19:55
02-28-2021 00:30
02-28-2021 00:30
02-28-2021 17:30
02-28-2021 17:30
02-28-2021 19:52
02-28-2021 19:52
02-28-2021 21:35
02-28-2021 21:35
03-01-2021 00:42
03-01-2021 00:42
I'm still confused - if your primary need is just an easy way to make a phone call from outside your coat while walking your dog, a decent but inexpensive Bluetooth headset device would be a much more direct approach to the task. And much simpler, much less expensive.
03-01-2021 06:50
03-01-2021 06:50
03-01-2021 18:56
03-01-2021 18:56
07-25-2021 18:44
07-25-2021 18:44
Switching the brick is what got my error to go away. Thanks for the tip!
