06-21-2018
23:20
09:24
HeydyF
06-21-2018
23:20
09:24
HeydyF
I received my charger and there us a rattling noise in it .. is it suppose to sound like that?
10-27-2018 03:56
10-27-2018 03:56
Hi,
i have the same problem with my charger, it works but sounds like there something broken inside
10-27-2018 09:37
10-27-2018 09:37
Hey @Chiaretta80, let me give you a warm welcome to the Community! In order for you to get further assistance, I have escalated your case with our Support team, so please keep an eye on your inbox so they will try to reach you soon.
Let me know how it goes!
11-01-2018 22:45
11-01-2018 22:45
Brand new Fitbit Versa here, opened the package to take out the charger and mine also sounds like it has a broken internal piece rattling around in it. Could Support please email me on how i can get a replacement?
11-02-2018 11:06
11-02-2018 11:06
Hey @SunsetRunner, let me give you a warm welcome to the Community! Since the charging cable of your Versa is doing a weird noise too, I have escalated your case with our Support team so they can take a look at your options. Keep an eye on your inbox.
Have a nice day!
11-04-2018 08:53
11-04-2018 08:53
My Versa will not turn on. I tried to charge it. It gets hot but nothing goes on. I tried to restart it by holding down the buttons. I cleaned the contacts and nothing. Then I noticed there is something loose inside the charger. It sounds like a very small part sliding around loose inside.
11-04-2018 18:04
11-04-2018 18:04
I think you need to contact Support with this (link in my signature)
Helen | Western Australia
11-06-2018 16:51
11-06-2018 16:51
Came here for the same issue, fitbit charging unit started to make a rattling sound. Should I just buy another charger?? Thank you.
11-07-2018 07:57
11-07-2018 07:57
Welcome aboard @Mamabear15623! Considering the issue that you have with the charging cable of your Versa, I have escalated your case with our Support team for them to further assist you. So keep an eye on your inbox.
I'll be around!
11-09-2018 20:34
11-09-2018 20:34
Hello, I bought myself another charger so I could have one in the office and one at home. But the charger makes a rattling noise when I took it out of the box. It's as though there is a broken component inside. Could I please receive some assistance with this issue? Thanks.
11-10-2018 05:00
11-23-2018 10:38
11-23-2018 10:38
Mines does this to
11-23-2018 10:41
11-23-2018 10:41
I just bought one and same issue!!!
11-23-2018 10:43
11-23-2018 10:43
What was the fix
11-23-2018 18:27
11-23-2018 18:27
I was told that as long as it charges properly i shouldn't worry about it and to let them know if it stops working
11-24-2018 09:41
11-24-2018 09:41
Hey guys! Let me give you a warm welcome to the Community!
@Wendy234, thanks for bringing this issue to my attention. I have escalated your case with our Support team so they can further assist you. So please keep an eye on your inbox.
@Chiaretta80, thanks for the update. I hope that your charging cable keeps working without inconvenience.
I'll be around guys!
11-26-2018 08:46
11-26-2018 08:46
My charger rattles too
11-26-2018 11:36
11-26-2018 11:36
Hey @Bvrgrl42, let me give you a warm welcome to the Community! Is it the charging cable of your Versa charging it fine? I mean, does it charge it completely? Does it charge it in the proper time-frame? Let me know. If that isn't the case, I will continue assisting you. 😉
I'll be around!
11-26-2018 15:07
11-26-2018 15:07
11-30-2018 04:32
11-30-2018 04:32
Hi, New Versa opened today, charger rattles as though loose component inside. Please advise on fix. Thanks
11-30-2018 04:46
11-30-2018 04:46
Mine rattles like most I've heard of, but it charges fine.
