06-21-2018
23:20
09:24
HeydyF
06-21-2018
23:20
09:24
HeydyF
I received my charger and there us a rattling noise in it .. is it suppose to sound like that?
Best Answer12-25-2018 12:05
12-25-2018 12:05
I have the same issue the Fitbit works fine ,but the charger rattles like something is broken.im worried about this .
Best Answer12-27-2018 17:36
12-27-2018 17:36
My Versa charger works fine, but has a rattle like something is loose inside. Is this OK? There are many on here that have the same issue. A response would be nice.
Best Answer12-27-2018 17:37
12-27-2018 17:37
@Fiery-Phoenix wrote:I have the same issue the Fitbit works fine ,but the charger rattles like something is broken.im worried about this .
Best Answer12-27-2018 21:23
12-27-2018 21:23
Best Answer12-28-2018 07:41
12-28-2018 07:41
Unboxed my new Versa and connected up to charge but noticed that when I move/shake teh charger it rattles. Is this normal or is there something broken inside?
Best Answer12-28-2018 13:59 - edited 12-28-2018 14:02
Hi, just checked my charger and when shaking it, it indeed rattles a little bit, but it functions flawlessly. So no worry as far as I'm concerned. To convince you about this: after charging my Versa fully, it will work for 5,5 days on one charge. Might even reach 6 days, but I'm always start charging whenever Fitbit app tells me my battery is low, which is about 24%.
12-29-2018 04:48
12-29-2018 04:48
Thanks for checking.
01-02-2019 11:22
01-02-2019 11:22
I just chatted with an agent about 5 minutes ago about the same problem. This is my second charger from them with the same issue. Although this charger still charges, I don't think the sound of the small piece moving around is a good sign. I asked if others were having this issue to which he stated "not many". So hopefully it will not be an issue, but I do have a reference # that I contacted them should something go wrong with it. Hopefully you can get a new charger too.
Best Answer01-02-2019 11:32
01-02-2019 11:32
I am having an issue with the rattling noise in the charger also. Most of these messages are from a long time ago. Can someone tell me if the issue has been resolved. This is my second charger and the same issue. At this point it is still charging but I don't think that "loose" sound is a good thing. Can the moderator please let me know if they have a solution? Thank you. Hope everyone has a Happy New Year.
Best Answer01-02-2019 21:39
01-02-2019 21:39
Best Answer01-03-2019 09:44
01-03-2019 09:44
They sent me a new one after my original in the box had that problem. This is the second one now that has the same issue. Hopefully it continues to charge and if not, they have a reference number from the call I made and will then just send me a new one.
Best Answer02-01-2019 17:34
02-01-2019 17:34
I just bought my fitbit versa today and the charger is rattling. What is wrong with it? Sounds like a piece loose in the inside.
Best Answer02-01-2019 18:42
02-01-2019 18:42
Best Answer02-04-2021 22:18
02-04-2021 22:18
Mine does the same thing; I contacted customer service and they acted like it was no big deal as long as it kept on charging, even though there was also a little piece of plastic broken off the charger that was in the box as well. However buying a BROKEN item doesn't sit well with me! And the charger stopped charging and never got to a full charge. My boyfriend pulled out his old charger and finished it the rest of the way. This weekend we will likely return the defective Versa.
Best Answer07-12-2021 14:30
07-12-2021 14:30
I have the same issue too. Please send me a new charger. Thanks
Best Answer07-16-2021 19:50
07-16-2021 19:50
Hello everyone. For all of you who are new to the Fitbit community, welcome.
I appreciate your participation in the Forums and sharing your experiences. I understand your concerns and appreciate your time and feedback. If you're experiencing this issue, please get in touch with our Support team so they can evaluate the issue and help you with this matter. Click here to get connected with them via chat or phone.
I am going to close this thread, but if there is anything else we can help you with, do not hesitate to start a new topic.
See you around.
