My Versa is found but wont connect
ANSWERED
I'm having trouble pairing my fitbit Versa to my honor phone. It was connected and then lost connection. I've tried several times, switching Bluetooth on & Off, also switched watch on and off but still nothing. I've also done a factory reset and now watch is stuck on the main screen. Any ideas or suggestions please guys?
1 BEST ANSWER
Accepted Solutions
Hi, which Honor phone do you use??
3 REPLIES 3
Its a few years old the 5C.
Hi, I cannot find in the two sites I know about Fitbit supported devices, the model you're using. However, the 6,6 Plus and 6X are supported by Fitbit. So, I would expect that the 5C is also supported but not in the list. Therefore I would suggest the following:
Maybe the guide I wrote to update to the newest Firmware Version might be helpfull for you, as I think that might be your problem now. I wrote it cause many users had problems updating to the newest version. My guide shows you how to use WiFi instead of BT to update. See: https://community.fitbit.com/t5/Versa-Versa-Lite/Hassle-free-guide-to-update-your-Versa-s-firmware/t.... Hope this helps!! And thanks for marking it as an accepted solution!!
