04-23-2018
13:31
19:40
EdsonFitbit
04-23-2018
13:31
19:40
EdsonFitbit
I used my Versa in the pool for the first time today. It tracked 14 of my 26 lengths. I didn’t stop/ rest/ change strokes part way through. It just didn’t work. Any suggestions?
Moderator edit: added label
04-24-2018 09:20
04-24-2018 09:20
Hey @Tarlia7, welcome aboard! You can also get some incorrect swim data because the units for the pool length setting don't match the units you use for your Fitbit settings. For example if you measure length in feet and inches, and specify a pool length in meters. You can personalize your Fitbit data, you can choose which units of measurement you prefer to see.
You can adjust the type of units used for your height, weight, water consumption, and swims in either the Fitbit app by doing this:
In addition, I'd like you to try to restart your Versa by following the instructions in this post.
Let me know how it goes!
Best Answer04-24-2018 09:23
04-24-2018 09:23
I had the same issue with the iwatch. Only tracked half my laps. Even worse is when you kick with a kick board. The iwatch doesnt track any of it.
