12-13-2018
22:50
16:50
EdsonFitbit
12-13-2018
22:50
16:50
EdsonFitbit
My Versa has started to play up. I can see that lots of other users are also having issues. My problem that is although the app seems to be working ok, I can't see anything sensible on the screen Sometimes I get the top bit of the Fitbit logo, and sometimes I get some of the clock face. When I press the left button I get 2 quick vibrations. What has gone wrong?
Moderator edit: added label
12-13-2018 22:56
12-13-2018 22:56
@maryharp pressing and holding the left button takes you to the quick menu on your Versa where and indeed makes your tracker vibrate twice. Re your screen issues, have you tried restarting your tracker several times by pressing and holding the left and bottom right buttons until Fitbit logo flashes?
12-13-2018 23:04
12-13-2018 23:04
Yes, I have tried pressing the bottom right button with the left button, but after the screen has gone black, I just get the top part of the Fitbit logo - not the whole thing.
12-14-2018 07:28
12-14-2018 07:28
Just to update further - my Versa is now not really holding any charge. The battery drained after a few hours, and the screen is unreadable.
12-14-2018 07:38
12-14-2018 07:38
Hi, for these kind of issues, I would like to advice you to seek contact with the Customer Service: https://help.fitbit.com/?l=en_US&c=Topics%3ATroubleshooting. The will be glad to help you. Good luck!
12-14-2018 12:42
12-14-2018 12:42
@maryharp Sorry to hear that. You can attempt 3-button factory reset, but this might be a hardware issue. If the factory reset does not help, you will have to reach out to Customer Support. Try charging versa before attempting factory reset:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
