12-18-2018
21:56
08:47
HeydyF
12-18-2018
21:56
08:47
HeydyF
My versa stopped working. When I put it on the charger it works. When I take it off the charger it does not work.
08-02-2020 03:15
08-02-2020 03:15
08-02-2020 03:28
08-02-2020 03:28
Here in the USA, the fitbit comes with a one year warranty. Apparently in some places, you could buy an extended warranty that would give you two years. It wasn't offered to me. I was offered the same deal through the first year. That is why I was strongly recommending that customer service be called immediately.
08-02-2020 08:15 - edited 08-02-2020 09:37
Having the same issue, watch will not stay on after it is removed from the charger. On the charger it reports 100% change. Hard and software reset doesn't fix it. The watch is just out of warranty too. This definitely seems to a defect Versa watches.
08-08-2020 12:05
08-08-2020 12:05
Did you ever resolve your problem with your fitbit. versa
08-08-2020 12:29
08-08-2020 12:29
08-16-2020 12:56
08-16-2020 12:56
While charging, my Fitbit versa works. Once I take it off, I have the same issue. Black screen. It will not reboot. I’ve been trying to charge it for over a day. Been switching out my usb plug ins, and all. Still can’t get it to work correctly. Sometimes it says 76%, 86%, 0%, or 100%. Either way once removed from charging port it becomes useless.
08-16-2020 16:29
08-16-2020 16:29
08-16-2020 23:56
08-16-2020 23:56
Hi, I know this is an old post but I'm currently experiencing the same challenges and have tried the suggestions with no success.
08-17-2020 00:02
08-17-2020 00:02
08-17-2020 00:10
08-17-2020 00:10
08-17-2020 06:57
08-17-2020 06:57
Update: I have contacted Fitbit customer service and explained them that my Versa works only in the charging cradle and once it is out of the cradle, it turns off instantly. I also explained them that I went through all possible troubleshooting steps including two buttons reset and the factory reset and it seems that the battery is defective. They asked few questions and offered me either a replacement with the same model (most likely refurbished) or 50% off for a new model. I have selected 50% off for a new model and picked Charge-3 which I will give to my wife as a gift.
08-17-2020 09:02
08-17-2020 09:02
08-17-2020 10:41
08-17-2020 10:41
08-17-2020 10:45
08-17-2020 10:45
08-21-2020 11:16
08-21-2020 11:16
Hi I’m having the exact same problem we have even tried a factory reset and now it won’t turn on at all the charger worked as it was charging it fully.
08-21-2020 11:38
08-21-2020 11:38
08-21-2020 12:33
08-21-2020 12:33
08-21-2020 12:35
08-21-2020 12:35
09-07-2020 05:38
09-07-2020 05:38
Hey I know this post is approx. two years old but i am having the same issues as this. My Versa turns on when i put it on the charger and then it turns off when i take it off. I have tried resetting and all but it does not work. Please advise @HeydyF
09-07-2020 09:18
09-07-2020 09:18
