10-04-2018
18:25
09:08
HeydyF
10-04-2018
18:25
09:08
HeydyF
Does anyone else think the charger for the Versa is garbage? I can't get it to sit flat because of the charging wire and the band knocking it over. The result of that is Fitbit didn't charge.... Help!!
12-27-2018 14:20
12-27-2018 14:20
Your video seems to show a Versa with a knit band, not the standard rubber band. The rubber band retains a curve that causes it to conflict with the power wire. For me the only way to "sit" the charging Versa flat on a table is with the face down. Off the top of my head, I don't see the design solution, but the current design of the charger seems flawed.
10-04-2018 20:19
10-04-2018 20:19
Welcome to the forums!
I dont understand. Are you using a fitbit Charger for your Versa? As the band lays over the charging cable.
Here is a YouTube video to show you how to charge it
https://www.youtube.com/watch?v=NpAQHdVWFB0
Hope to see you around the forums!
Wendy | CA | Moto G6 Android
12-27-2018 14:20
12-27-2018 14:20
03-11-2020 11:16
03-11-2020 11:16
I am having the same issue. I have placed my versa 2 on the charger, plugged into a brick and plug that have both been tested to work.
I have removed the band so nothing could get in the way and versa does not recognize it is on the charger.
I've wiggled it, held it in place, cleaned the contacts etc
Nothing seems to work
