05-28-2018
14:55
19:20
EdsonFitbit
05-28-2018
14:55
19:20
EdsonFitbit
My battery on the Versa is not lasting a day, first 2 weeks of having it it lasted up to 4 days but now I’m lucky it lasts a day.
I have tried all the battery saving things Fitbit suggest in their help page. I’m not sure what else to do
Moderator edit: added label
05-28-2018 14:58
05-28-2018 14:58
@Domino666 wrote:My battery on the Versa is not lasting a day, first 2 weeks of having it it lasted up to 4 days but now I’m lucky it lasts a day.
Try a Restart and do it several times if necessary.
05-28-2018 15:01
05-28-2018 15:01
Hi I’ve tried that already it’s still not improved it. And yes already read the manual
05-28-2018 15:03
05-28-2018 15:03
05-28-2018 16:46
05-28-2018 16:46
If Restart isn't working, you need to try a Factory Reset which puts the tracker back to how it was when you first set it up and you will have to start over from scratch. Swipe left to Settings, then to About and then Factory Reset. Allow about 30 minutes to an hour to complete.
05-28-2018 18:04
05-28-2018 18:04
Doesn't work. Having same issue, the .15 update has destroyed the battery.
05-29-2018 00:44
05-29-2018 00:44
Yeah it’s been since the update the battery has dropped dramatically
06-05-2018 09:38
06-05-2018 09:38
Ive tried the factory reset as
well the battery life has disappeared from the first few weeks of having it and I haven’t changed from the standard settings I’ve had since the start
06-05-2018 09:54
06-05-2018 09:54
I currently have 3 1/2 days on my initial charge and have the 32.32.10.15 firmware installed. I am down to 21% after 86 hours... I read on another post that using watch faces OTHER than the ones developed by Fitbit can cause battery drain...just a thought.
06-05-2018 10:03 - edited 06-05-2018 10:04
@Domino666 wrote:Ive tried the factory reset as
Time to contact Customer Support.
