10-20-2018 13:16
10-20-2018 13:16
My daughters Versa will not switch on and won’t charge
Best Answer10-20-2018 16:28
10-20-2018 16:28
Are you sure you have pressed it properly into the cradle? You might need to fiddle a bit.
Best Answer10-20-2018 19:42
10-20-2018 19:42
The problem may be with the charging cradle...
I had the same problem with my Versa. The charging problem was with the USB connector on the cradle. Regardless of how many different charging blocks I tried, the only way I could get it to charge was to hold the cradle connector firmly in the charging block - as soon as I let go, charging stopped. I exchanged the Versa for a new one and the new charging cradle works fine...
Best Answer10-21-2018 01:06
10-21-2018 01:06
Best Answer10-21-2018 11:39
10-21-2018 11:39
The Fitbit worked fine - it was the charging cradle that wouldn’t work. I was able to exchange the entire package - Fitbit, extra band and charging cradle for for a new package, no questions asked by the retailer. The new charging cradle works just fine...
