My distance won't show up on my Fitbit app
Mileage shows up on the device but no data shows up on the app!  Everything else is working!
3 REPLIES 3
Hi there, @Sigsbee502. Welcome to the Community Forums.
It seems like your distance tile has been accidentally hidden. To add (or hide) stat tiles:
  1. On the Today tab > tap Edit.
  2. To add a stat tile, swipe down and find the stat you want to add > tap Add. To hide a stat tile, tap the X icon on the stat you want to remove.
  3. Tap Done.
For more information, see How do I use the Fitbit app?
Hope that helps.
Thank you!  My mileage shows up on the dashboard but does not show up under the Exercise.  No data is being recorded!
Did you find an answer to this? Mine is doing the same thing.
