My fibit is stuck on restart screen
Hi, I've had my fibit for 2years and it's only recently been having problems. First it wouldn't connect to my phone or update. Then I tried restarting it and it go stuck on the fitbit logo. Please help
Thank you.
5 REPLIES 5
Try
  • Remove your Versa from your Fitbit account and from your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Setup your Versa again.
  • If there is no connection, restart your Versa.
help article: Why can't I set up my Fitbit device?
Hi, I have tried this but my fitbit app will not pick up my Fitbit. My versa is still stuck on the restart screen and is not connected, I have tried restarting it but it stays on the screen.
Thanks
Did you do?
In the phone Fitbit App
Click on profile photo [top left]
Click on  + Set up a Device
Follow the installation instructions
I have the same problem.  It started this week.I tried to do a factory reset pressing the 3 buttons but it didn't work.
After i contacted Fitbit support they tried several things and finally they said I need to proceed with the warranty claim. Problem is I bought  it in July 2019, and they offered a discount for next purchase  but I won't buy this anymore.I truly believe this problem was generated by a software update that didn't work
