03-19-2020 23:59
03-19-2020 23:59
My fitbit watch is not restarting after factory reset. What to do?
03-21-2020 15:33
03-21-2020 15:33
@aakanksh Rub the contacts with alcohol and place the watch on the charger for several hours, then
attempt the factory reset using button(s):
For Versa 1:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
For Versa Lite and 2:
You can set up the watch back to the Fitbit account by following the instructions on this link: How do I set up my Fitbit device?
If you're not successful with the factory reset, I am afraid you will need to reach out to Customer Support to guide you through the next steps. Here's the link to Customer Support page.
Best Answer03-20-2020 17:38
03-20-2020 17:38
@aakanksh Could you please explain? Does Versa turn on? Is the screen on but the watch is not pairing? What happens when you put the watch on the charger? Is your fitbit still linked with your account (can you see it in the fitbit mobile app)? Also, what phone model and OS do you have?
Best Answer03-20-2020 19:27
03-20-2020 19:27
I have similar problem. Turns on tells me to sync in multiple languages. Gave up don't wear any more.
Best Answer03-21-2020 01:42
03-21-2020 01:42
Best Answer03-21-2020 02:05
03-21-2020 02:05
I am having the exact same problem. Tried all the tricks online but no joy. The watch is not responding to anything and has been on charge for 3 days now. This must be a bug in the latest update.
Best Answer03-21-2020 14:17
03-21-2020 14:17
Is this the original Versa (with 3 buttons)? If so, press and hold the left and bottom right buttons for like 10-15 seconds and see if that works.
Best Answer03-21-2020 14:31
03-21-2020 14:31
Best Answer03-21-2020 15:33
03-21-2020 15:33
For Versa 1:
Best Answer08-01-2023 06:27
08-01-2023 06:27
My Versa went dead a month ago and I eventually figured out how to to a hard reset, and it worked fine (the trick, which I learned thru other posts on this forum) was to connect the charger to my laptop. This time, it went dead and I tried the same thing. Didn't work, and now after several days of keeping it on the charger, the Versa remains dead except for this - every once in a while, the watch will light up with the multi-language set-up logo (blue fitbit logo with the scrolling message telling you to pair with your app). So I go to the app, initiate a new set up, I get the 4-digit code, enter it, I get the green checkmark, then when it goes to initiate the set up (over wifi or bluetooth), the watch shuts itself down (which I know because my laptop makes the little noise indicating the device is off). Then the app just cycles over and over trying to locate the watch. I've gone through this so many times that I've lost count, and same pattern.
When the watch goes dead like this, I can push and hold the reset buttons until my fingers are sore and nothing happens - but on my phone, it shows that the watch is paired to my phone's bluetooth. And strangely enough, sometimes it even still syncs, but when I try to manually sync, I get nothing. I've reinstalled the app a couple times, cleared the cache and data, turned the phone on & off, toggled the bluetooth on and off, I am out of ideas.
Any help on this or is the watch trash now?
Best Answer08-01-2023 19:04
08-01-2023 19:04
Same problem. Tried the all processes. but nothing happen.
Best Answer08-01-2023 22:28
08-01-2023 22:28
I'm having the exact same problem, too. And nothing is working to get it to restart. After a day on the charger, it sometimes shows me the original startup screen with the different scrolling languages and the Blue logo. I open the app, initiate a new set up, I get the 4-digit code, enter it, I get the green checkmark, then when it goes to initiate the set up (over wifi or bluetooth), the watch shuts itself down. initiate a new set up, I get the 4-digit code, enter it, I get the green checkmark, then when it goes to initiate the set up (over wifi or bluetooth), the watch shuts itself down.
Best Answer08-01-2023 23:26
08-01-2023 23:26
Hi @mama_k314 - good troubleshooting but did you try to remove the watch entry from the phone's Bluetooth and from the Fitbit account, and turn off any devices with the Fitbit App running?
Then do the trouble shooting steps already done, logout, clear ,restart phone and watch, then with the 2 devices near each other and the wifi source, try again.
Best Answer08-01-2023 23:38
08-01-2023 23:38
Hmmm, I have tried each of those things more than once, but maybe not in succession. Are you suggesting doing that entire cycle, in that order? At this point, it can't hurt to try, otherwise, my Fitbit is gonna remain a paperweight...
08-01-2023 23:42
08-01-2023 23:42
@mama_k314 - the order is important. Also if you get the multilingual start up screen on the watch and can enter the code it would seem the watch is serviceable and it is just the installation that is failing.
You can always chat via the Fitbit App, click profile photo, Help & support, Contact Customer support.
