07-23-2021
13:47
17:06
07-23-2021
13:47
17:06
I’ve just received my replacement versa lite and it says Spotify is not compatible when I had the app on my old one?
Best Answer08-05-2021 17:07 - edited 11-01-2023 18:02
Hi there, @Varst95. Welcome to the Community Forums.
Since you have just setup your Versa Lite it may appear up to date but it needs another update so you can be able to download and use Spotify on your new watch. The latest update isn't available until up to 48-72 hours after setup. For more information, see What's changed in the latest Fitbit device update?
If you've waited longer than 72 hours, Id recommend performing a factory reset on your Versa Lite to see if this allows you to upgrade your watch to the latest version. Before doing this step, please make sure to sync your Versa Lite to your Fitbit app so all your data is sync and up-to-date. Nevertheless, take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
With that being said, follow the steps below to complete the factory reset:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Once the above has been done, please allow your watch 48 hours to see if the update is available and ready for you to download.
Hope that does the trick for you.
