12-12-2018 03:12
12-12-2018 03:12
I just purchased a new fitbit versa and it wont connect to my wifi network at home. I tried all the trouble shooting like turning the watch on an off and disabling Bluetooth still not connecting. I even checked my wifi connection and all my other devices seem to be connecting fine. What can I do? its driving me nutsss and Im very disappointed..
12-13-2018 08:10
12-13-2018 08:10
Generally with a dual band router you will see to wifi networks.
This is what mine looks like.
i simply told my Fitbit to connect to the -2.4 network.
My computer is attached to the-5.
The -EXT extension router doesnot have 5, but is needed to get the coverage I need.
Since all three of these are on the same home network we can consider them as one network.
I would for ease have the phone connect to the 2.4 while setting up the wifi on the Fitbit. Once the tracker has been setup the phone can be switched back to the 5 gig.
Then when the Versa is plugged in to charge it should try and connect to the 2.4.
Some people like to disable the 2.4 on their dual band router and this would be a problem.
12-12-2018 06:03
12-12-2018 06:03
have been having this same issue since i purchased the watch which was earlier this year.
12-12-2018 08:24
12-12-2018 08:24
A few things to check:
Is Fitbit comoatcompwi h your router settings?
Is the tracker plugged in and charging?
Is the phone connected to the wifi?
Do you get any error messages? If so please pass them on.
Is the wifi password correct?
Here is a few first bit help docs that may help
12-12-2018 16:07
12-12-2018 16:07
yes to all of your questions except the first how do I check my router settings? Also the error message that pops up when trying to connect via fitbit app on my iphone is, "This wifi network is not available, please try a different network". This is confusing because all my other devices are connected fine I cant figure it out still.
12-12-2018 16:09
12-12-2018 16:09
yes to all of your questions except the first how do I check my router settings? Also the error message that pops up when trying to connect via fit bit app on my iPhone is, "This WiFi network is not available, please try a different network". This is confusing because all my other devices are connected fine I cant figure it out still.
12-12-2018 19:10
12-12-2018 19:10
try using your phone as a hot spot and connect to that. I had problems connecting to a dual band router as the versa uses 2.4 mhz. only and my router uses 2.4mhz. and 5mhz.
It may help, it helped me when I couldn't download from pandora. It kept saying network not available.
dave
12-12-2018 20:19
12-12-2018 20:19
I'm having the same problem.
12-13-2018 01:29
12-13-2018 01:29
yeh I tried that and it connected to my iphone hot spot. I think my router is the same as yours thats really crap of fitbit really dissapointing..
12-13-2018 08:10
12-13-2018 08:10
