My run shows map from a previous walk-Versa 2
Hi,
When I open my activities and check my latest run it shows the map of a walk from a few weeks ago. When I click it for details it does show the correct map.
Already reinstalled the app and closed it a few time. It’s not a real big problem but if seems like some caching problem that can easily be solved. Are there more people with this problem?
1 REPLY 1
Thank you for visiting the Fitbit Community @Linfon85.
Thanks for the information provided and for trying to resolve the issue before contacting us.
Please try the following:
- Log out from the Fitbit app
- Reboot your phone
- Log back into the Fitbit app
Whether this doesn't help, you can set up your Fitbit Versa 2 as a replacement device:
  1. Tap the Today tab, and tap your profile picture.
  2. Tap Set Up a Device.
  3. Choose your device and follow the on-screen instructions to continue.
Hope this helps.
