02-26-2019 09:54
02-26-2019 09:54
Everything was okey this morning, but battery was getting low, came home to charge it, but there nothing in display but the blue screen. Restarted and it started chargind but now its not working anymore 😞
02-26-2019 12:34
02-26-2019 12:34
@Grete110 Please try rebooting it several times by pressing and holding the left and bottom right buttons until Fitbit logo appears. If this does not help, please try 3-button factory reset:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear. Let me know if that worked for you. You may need to reach out to Customer support if you're not successful.
02-26-2019 12:34
02-26-2019 12:34
03-01-2019 11:14
03-01-2019 11:14
@Grete110 Did you manage to resolve the issue? Did you reach out to Customer Support?
Best Answer03-01-2019 12:09
03-01-2019 12:09
Best Answer03-01-2019 12:17
03-01-2019 12:17
@Grete110 Thank you for the update. It may take a while but your Versa is still under warranty, so it all should turn out fine. Good luck!
