My versa wont turn on with the flip of the wrist
I just got my versa a few days ago and the watch face will not turn on when I flip my wrist. I have to hit the button on the left to see the time. How can I fix this? I don't seem a setting for this.
50 REPLIES 50
Thank you, i thought i had to buy a new watch.
You’re welcome 😊
Thanks! That was a simple fix. Much appreciated that you posted it as mine was off. Fixed!
Thank you very much - this worked for me.  Not sure how it got switched to manual because it worked originally and then suddenly didn't.  Appreciate your easy instructions.  Now I have to figure out why I'm getting frequent and repeated "Bluetooth Issues" warning when I open the app..............very frustrating.
Thankyou! Somehow mine had switched off! Thankyou! Thought was going faulty, like the first one I had 🙂 x
I am new to Versa as of today.  You said to hold the main button until it vibrates, which button would that be?  When I open settings on the watch and view Screen Awake I do not see "Auto", only seconds in varying increments
You go onto Fitbit app, then selected the watch at top left. Then across down and underneath the exercise shortcuts should be quick view- you just swipe across so green.
After you have done that reset watch by holding the left hand and the lower right together till you see the fit bit symbol then release. This was the solution for me.
Sent from my iPhone
That seems to have done it, Thank You!
Do you know anything about Versa not displaying Notifications?  I see that you
are on an iPhone while I am Android so that surely makes a difference.
Yes it is delayed though. Sometimes when phone right next to me is quick but sometimes is extremely slow as in takes 30 mins! Make sure the watch is empty of notifications. So on main clock face swipe up and make sure you clear all. And sometimes that makes it quicker.
Glad I helped! It’s extremely frustrating!
Sent from my iPhone
Thank You!
Thank you, it worked!!!
I've tried all the suggestions to get my versa screen to turn on with wrist twist. None of it is working with my watch. Please help!
Have you tried what I previously said? Or can you not see it?
Get Outlook for iOS
I cant see it.
That did not work either.
I did swipe down there is nothing that say quick look
Thanks for the tip!
This worked for me! Thanks so much!
Thanks. Got a replacement Fitbit and it wasn't showing on wrist flip. This fixed it. 🙂
