05-01-2018
06:17
17:17
EdsonFitbit
05-01-2018
06:17
17:17
EdsonFitbit
When I go to the weather app on the app, it says to type in a city and i do but it doesn't do anything. I can't select it. If i try to select use my current location it doesn't do anything either. I have already changed the settings for fitbit to always have access to my location.
Moderator edit: added label
05-01-2018 06:57
05-01-2018 06:57
I was having the same problem with my Versa too. I've seen others complain about this. Good thing that FitBit says that everything has been resolved. I'll be able to try again once I get my new Versa since my first one proved to not be water resistant in the shower, lol.
Best Answer05-01-2018 07:02
05-01-2018 07:02
whoops! This hasn't been resolved for me, i tried it right before i posted 😞
05-01-2018 07:19
05-01-2018 07:19
All Day Sync has to be turned on for the weather app to work.
"If you turn off All-Day Sync, certain apps including Weather won't work since data isn't being sent from the Fitbit app to your watch."
Best Answer05-01-2018 07:28
05-01-2018 07:29
05-01-2018 07:29
I can't even select a city.
Best Answer05-01-2018 07:56
05-01-2018 07:56
If I turn on all day sync, my Versa stops sending notifications. If that's the only way to get the weather, then I'd rather have no weather updates than no notifications. I'd say it's a phone issue, since I use a phone that isn't supported, but the Versa does the same thing when I use a Lumia 950 which IS supported.
Best Answer05-01-2018 07:58
05-01-2018 07:58
I was just being sarcastic when I say things are resolved. Nothing has been resolved and everyone is still having problems. Fitbit just says things are resolved.......I'm sure however that given time, things will be worked out.
05-01-2018 08:14
05-01-2018 08:14
My bad...
I have an iphone. I get most of my text notifications, i had a problem the other night it wasn't syncing right but after that my texts came through fine.
I know it's new and there are bound to be bugs, but seems like there was a lot..
