Need help replacing Pace with Calories in the "Workout" section
When I post the results of a Workout (using the Share link to post in the Community area), as far as stats go, I'm seeing: average bmp, miles, minutes, and pace, all with the line graphic. I want to replace Pace with Calories Burned. How do I change that setting? I have an iPhone.
1 REPLY 1
Hey...i had the same problem.
It was annoying me so much but I finally figured it out today while i was playing around with my fitbit versa watch after a workout.
I came on this forum to search how to rectify the problem but i only could see that u had the same problem and as me.
Anyway this is the only way to change the settings for every exercise that u want to do.
Step 1 - Go to EXERCISE on ur fitbit versa watch
Step 2 - Scroll across to Workout and then click on the little settings icon on the top left hand corner of ur watch screen
Step 3 - Turn off show laps
Step 4 - Scroll down and click on CUSTOMIZE STATS. This will take u to the section where u will be able to control the 3 stats that u want the fitbit community to see wen u post a workout.  U will see TOP STATS, MIDDLE STATS and BOTTOM STATS. And this is where u select the stats (heart rate, distance, calories etc.) that u see wen u share ur workout. Lap time is the same as distance in the settings for workout
NOTE
U will have to repeat all of the above wen ever u decide to track a new workout bocs the settings goes back to its original settings .
And u can customise the stats for weights, run, bike, treadmill and all the other exercises too by following the same steps
