Need to do hard reset to turn on the versa 1 watch
Everytime i turn the watch off and want to turn it on again no matter how long I hold the power on button the watch won't boot.
Holding the right down button and power for 10 seconds works
Why is the watch acting like this?
4 REPLIES 4
Never mind.  My original idea turned out to be incorrect.
anyone experiencing the same?
I know of a couple of people in your situation.  But I don't think it's a reason for concern.
It's not really a "hard reset", just a restart, which is standard first step to resolve any situation.
Despite all the references I see to had and soft resets, etc, there are only 2 such Fitbit procedures:  "restart" and "factory reset", and I believe other terminology often leads to confusion.  "Restart" can be done anytime, fixes some problems, and does not have any adverse effects.  "Factory reset", on the other hand, is a more extreme procedure that, in my opinion, is overused and can cause problems.  At the best, it loses all the device settings.  And I also see several posts of users doing a factory reset on their own, then the device not coming back at all.
Okay thank you for that clarification. I just noticed it and it seems a bit strange but otherwise the watch work :).
