08-05-2022
11:36
17:08
08-05-2022
11:36
17:08
My new Versa 2 Battery only last 48 hours, I was under the impression from the info I got on Amazon that it should last 4 days, the other problem I have is with the App which keeps asking me to pair the Versa to my iPhone even though the blue tooth shows it connected and I'm able to sync it.
08-05-2022 17:11 - edited 12-22-2023 03:33
Hi there, @1-Lucchese. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. I understand where your concern is coming from and how you must be feeling.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Hope that helps.
Hope that helps.
08-08-2022 07:06
08-08-2022 07:06
