12-30-2022
15:53
03:14
12-30-2022
15:53
03:14
I received a Fitbit versa 2 as a Christmas present. What is the slit that's right next to where the cable comes out from for? It's big enough so that the cable does fit in it, If you go higher up on the cable to attach it. The only thing I can think of is that you put the cable through the slit up by the USB part so that while charging it sits upright. I noticed the second I did this with my watch on the charger it showed a charging cable emoji on my watch face, indicating it was charging. Is this what it's for?
If anyone knows why it's there & what it's for, please let me know, or have I solved the riddle? Not knowing is a BIG pet peeve of mine.
Thanks for any info,
Shannon
12-31-2022 03:15 - edited 06-13-2023 10:29
Hi there, @Shanlecon1. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your new Versa 2.
If you continue having issues to charge your Versa 2 after following @Guy_'s recommendations, please see Why isn't my Fitbit device's battery charging?
12-30-2022
22:02
13:08
12-30-2022
22:02
13:08
Hi @Shanlecon1 - The watch sits in the cradle and you merely plug the USB into the power source. As shown in this link
How do I charge my Fitbit device?
The slit may help feed the wire out so it sits upright but it isn't as practical as the Versa charger of the same design where the wire comes out the back.
