05-28-2020
19:20
14:56
05-28-2020
19:20
14:56
Just bought a versa 2 from Sams Club and charged it overnight with a phone brick (fitbit logo showed so it was definitely using power) It wont turn on. Completely black screen once removed from charger. Have tried every combo of holding the side button down. Quick presses and holding for long time. Have switched charger ends to confirm it wasnt a bad charge. Any tips?
06-21-2020 14:58
06-21-2020 14:58
Hi there @FlorenceFiguero, welcome to the Community Forums. Thanks for the details provided about your new Versa 2's behavior. I appreciate you've taken the time to troubleshoot your watch prior to posting here.
As per the description of your post it seems that the battery on your watch may not be charging properly and therefore does not turn on. I recommend that you follow these steps (or please confirm that you've followed them as described below):
If the above steps don't work, at this point I recommend doing a factory reset:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Keep me posted.
Best Answer06-21-2020 14:58
06-21-2020 14:58
Keep me posted.
