07-25-2022
03:30
17:44
07-25-2022
03:30
17:44
Just got brand new versa 3. Have left in on charge in 3 different plugs, and connected to computer USB port.
Doesn't respond in any way to me tapping or holding the button, it just constantly vibrates intermittently.
07-25-2022 11:19 - edited 11-15-2023 16:09
Hi there, @JohnstonL. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
Probably the issue is with the Versa 3 and not the charger or charging ports. I'd recommend trying the tips and recommendations provided here Why isn't my Fitbit device's battery charging?
If that doesn't help, as @NellyG has suggested, the best way to get help for this problem is to chat with us online again or give us a call. Click here to get connected. Our team will let you know what your options are at this point.
We hope your issue is solved soon.
Best Answer07-25-2022 05:46
07-25-2022 05:46
Hi @JohnstonL Oh no, that is a shame! You will need to return it to the store you bought it from. If you got it from the Fitbit online store then contact Fitbit Support
Helen | Western Australia
Best Answer07-25-2022 11:19 - edited 11-15-2023 16:09
