05-13-2023
		13:37
		10:15
		05-13-2023
		13:37
		10:15
I’ve got a new Versa 3 & I can’t set it up. When I try to pair with Bluetooth it asks me for a 4 digit passcode. I haven’t set a passcode, so I don’t know why it’s asking me. Support gave me a method to do a hard reset, but it doesn’t work, it just keeps returning to the Home Screen. Could anybody confirm how to do a reset without the app, as the watch hasn’t registered.
05-13-2023 14:29
                              05-13-2023 14:29
Hi @Gemolition here are the directions to set up your new Versa 2 - click to read. As you set up, it will generate a four digit code on the device, so that is the one you use to continue the set up. You will need a compatible smartphone or tablet to get the app in order to set up. Read the article and see if setting it up by those instructions helps to get you going. Let us know how things go for you.
 Best Answer05-14-2023 10:23 - edited 05-14-2023 10:23
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
Hi there, @Gemolition. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out. @Odyssey13 Thanks for helping out.
As our Support Team has mentioned, please note that your case was forwarded to our higher tier of support for further checking. Someone will be in contact with you soon as they have the resolution for your Versa 3.
I hope we can solve your issue soon.
Was my post helpful? Give it a thumbs up to show your appreciation!  Of course, if this was the answer you were looking for, don't forget to make it the Best Answer! Als...
05-14-2023 12:03
05-14-2023 12:03
