03-03-2021
23:04
20:47
03-03-2021
23:04
20:47
Hi! I have just swapped from charge 2 to versa 3 and my sleep log hasn't been recorded automatically. I have had to manually put in my start and stop sleep times. How can change this to automatically logging my sleep?
03-04-2021 02:49 - edited 11-16-2023 11:18
Hi there @Missnikij, welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 3.
Since you just bought the Versa 3, give the RHR a few days to settle down. It does some calculations, looking at heart rate throughout the day and while you are sleeping, so it might just not have enough data to give a reasonable value yet.
In addition to that, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
Hope that helps.
Hope that helps.
07-29-2022 04:00
07-29-2022 04:00
I tried all that on my versa 3 and it still doesn't register any sleep at all.. It didn't do it with the versa too either.. Thought updating to the verse of 3 would fix the problem but it doesn't. Very frustrated think I'll have to switch to garmin garmin or a Google smartwatch which I really don't wanna do but OK you leave me no choice
07-29-2022 06:32
07-29-2022 06:32
Same exact for me. It's one of the main reasons i system with this brand is cause how will the charge hr2 was so good at this
