07-13-2018
14:24
09:21
HeydyF
07-13-2018
14:24
09:21
HeydyF
Just got my replacement Versa and have completed the set-up .... The vibrations are much weaker than my original one, I keep missing notifications I have it set to Strong, but notice when I am in the settings and make the change to the settings there is not real difference in the strenghts.
Is this one broke too? Ideas to fix ? Grrrr
I don't want to be without it for another month! Grrrr
Help
Best Answer07-14-2018 09:20
07-14-2018 09:20
Hey @LtBurt, I hope you are doin' great! If you feel that the vibration on your new Versa isn't as strong as it used to be on the previous one, I would suggest you to try to restart your Versa by following these instructions:
Let me know how it goes!
Best Answer07-14-2018 10:31
07-14-2018 10:31
@LtBurt wrote:I have it set to Strong, but notice when I am in the settings
Hello @LtBurt
I went from a Charge and Charge HR to the Versa and I find the vibrations are the same for me. I have just kept the Versa setting on normal as it does the trick for me.
I also wear my band so it doesn't slip around my wrist, so saying that, it is comfortably tight on my wrist.
Would tightening it another notch work for you. Just a suggestion.
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
