04-25-2019
10:37
04:45
JuanJoFitbit
04-25-2019
10:37
04:45
JuanJoFitbit
Have done all that but still not connecting to my phone.
Moderator edit: format
04-26-2019 11:11 - edited 04-26-2019 11:20
Hello @Sonti , may we have a little more information please?
What type of phone do you have?
Is the problem that you ate unable to setup the Versa/Versa Lite to your Fitbit account?
Or is the Versa/Versa lite already setup and will not sync?
Or does the Versa/Versa Lite sync but you do not get notifications?
Maybe everything above works fine but the GPS does not work while out walking?
The above all relate to connection issues with the phone, connection to wifi is unrelated and have moved this into its own thread.
Best Answer04-27-2019 04:45
04-27-2019 04:45
@Sonti Welcome to our Fitbit Community! I'm sorry for the late response. However, I would like to follow up and would like to know
I would like to follow up and would like to know if the issue persists or if you were able to connect your Versa with your phone.
In the meantime, please follow the troubleshooting steps that are listed in this help article.
Thank you so much for your help @Rich_Laue!
Looking forward to your response! 😀
Best Answer04-27-2019 05:18
04-27-2019 05:18
Best Answer04-27-2019 07:44
04-27-2019 07:44
Hello @Sonti I'm not sure if it is possible to connect to the phones hotspot. I find that the phone needs to be connected to the wifi that the tracker is going to be setup to.
Steps I would try.
Plug the Versa into its charger and make sure it is charging.
Turn the Hot Spot on then try setting up Wifi, putting in your phone's hotspot credentials. See FAQ question 1 to check if your phone's hotspot is configured properly. 5 mhz will not work.
If the above fails try the following steps, we are going to use your phone for the wifi connection and use a second phone to do the wifi setup on the Versa.
Make sure your phone's hotspot is on when, during a charging cycle and you want to update music or have the Versa check for app updates.
Please remember that the only thing that can not be done through your phones bluetooth is music transfer, therefore or your not interested in loading music onto the Versa their is no need to setup wifi.
Now you can open your phone's Fitbit app and turn on Bluetooth.
