01-16-2019
02:03
09:11
MarcoGFitbit
01-16-2019
02:03
09:11
MarcoGFitbit
I took back my versa today for faulty biometrics, the new versa I received will not update. I have tried everything I could find on the forums, nothing seems to be working. Any suggestions?
Best Answer01-17-2019 09:18
01-17-2019 09:18
Hello @danielle__, have a warm welcome to the Fitbit Community, it's great to have you on board. ![]()
I appreciate your participation in the Forums and for sharing your experience wtih us. Tell me, have you tried to restart your phone and your Versa by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen? If so, before you begin the firmware update, make sure your watch is plugged into the charger and in range of your Wi-Fi network during the update. For best results, use your home or work Wi-Fi network. If you've never connected your watch to WiFi, see How do I connect my Fitbit watch to Wi-Fi?. If your Versa is having trouble updating with WiFi, please try the following:
If the update fails, restart your mobile device and try to update again. If your Versa can't update over WiFi follow the on-screen instructions in the Fitbit app to update your watch over Bluetooth instead. Note that firmware updates over Bluetooth may take significantly longer to complete. If the Versa is having trouble updating through Bluetooth try the following:
I hope this can be helpful, give it a try and let us know the outcome.
Best Answer01-17-2019 23:53
01-17-2019 23:53
