12-31-2018 14:58
12-31-2018 14:58
Just bought a new versa and having syncing issues along with reading all the hoops you have to go through just to get it working I'm thinking of returning it. These watches cost to much to have to do half a million things just to make it work.
12-31-2018 15:06
12-31-2018 17:53
12-31-2018 17:53
12-31-2018 19:32
12-31-2018 19:32
I am also having trouble getting my new Versa set up. It will sync, shows it is connected to wi-fi but then has been almost 3 hours on the screen "Setting up Versa Step 1 of 3" connecting....
How long does it take?
12-31-2018 21:47
12-31-2018 21:47
01-01-2019 12:47
01-01-2019 12:47
Android 7.0
As for OS not really sure what to say when ask as its a phone?
01-01-2019 12:48
01-01-2019 12:48
Sorry the phone is a LG K20 Plus
01-01-2019 18:29
01-01-2019 18:29
@Diamond1868 It shouldn't take that long. Restart the whole process. Reboot your phone, and Versa by pressing and holding the left and bottom right button until Fitbit logo flashes. Place Versa in a charging dock and make sure both devices have access to a strong wifi network. Also, from my experience devices need to be very close to the router.
01-01-2019 18:33
01-01-2019 18:33
@Deevaz wrote:Android 7.0
Ha? Not sure what you mean. I asked what your phone model was and Operating System? If iphone, which iphone model and version of iOS. If Android, which phone model and which version of Android.
Now, regarding your phone model, I cannot see it on the compatible devices list. It doesn't mean it won't work with Versa. It means Fitbit haven't tested it yet. Some features might not work as designed. What are the issues you're having?
01-01-2019 20:12
01-01-2019 20:12
01-01-2019 20:51
01-01-2019 20:51
@Deevaz It simply means it hasn't been tested. Everything might work or some troubleshooting might be required. 🙂
01-02-2019 01:53
01-02-2019 01:53
Honor 6x
Android 7.0
Versa firmware 32.33.1.30
App version 2.84 (20213341)
Had my Versa 3 days now and syncing is challenging especially after a phone boot.
Bluetooth reports it is paired (both to Versa and Versa Classic) but that first sync after turning my phone on in the morning really grinds - sync has to be manually started and then maybe some of the data is transferred. Eventually after several attempts to sync the overnight data is transferred. Subsequent syncs can be as painful but then i decides to play ball.
I've restarted Bluetooth, repaired, reset watch, rebooted phone, force end and cleared app cache, completely uninstalled and reinstalled, configured app settings as per guidance.... nothing seems to resolve it, the next time i turn on my phone in the morning its the same dance.
Am I missing something? I shouldn't have to spend an hour jumping through hoops every morning getting it to start syncing. My previous Sony SWR30 would just connect and sync in the morning, I'd expect the Versa to do the same.
01-02-2019 09:01
01-02-2019 09:01
01-02-2019 20:03 - edited 01-02-2019 20:03
@Diamond1868 Please do, and good luck! Remember to have your Versa charging while performing the update!
01-02-2019 20:06
01-02-2019 20:06
01-12-2019 13:38
01-12-2019 13:38
Checked all the kill settings and the app is protected, will not be killed when lock screen enabled etc
Still finding issues with the sync though.
Turn on phone on the morning, says it's connected but no dice until I turn Bluetooth off and then back on again. Eventually I get a sync.
Can also lose the connection at random points during the day, will notice it's not synced, try the manual button and again no dice and have to cycle the Bluetooth. Then after a couple of attempts it syncs again.
Any advice? This is a supported phone with no other Bluetooth connections.
01-12-2019 17:18
01-12-2019 17:18
01-12-2019 22:24 - edited 01-12-2019 22:26
@Deevaz @David68 Then brutally honest, roll back fitbit app to 2.74.2. This is the only build that would stably sync, connect GPS, send notifications, etc. Still need to lock the app, turn off the battery optimization, turn on all the widgets and stuff, but perhaps this will work for you... You will not be able to log water with Versa though. Or use Custom emojis in quick reply. But I think that's about it.
